VRay 2.0 RT GPU
Installed Vray 2.0 and RT GPU didnt work. CPU is fine, but with GPU when building opencl trace program, nothing happend, didnt go beyond.
I don`t know if you have the same issue like me, but when I started a simple scene with no materials assigned by myself, RT doesn`t work. Maybe you can try to assign a VRay material from the VRay adv. 2.00.01 section. In my case it now works fine (I have newly assigned the max.vray UI scheme under the “Custom UI and Default Switcher”)…
You have to move the camera or perspective to get a view. Also, it takes a bit of time to build the opencl. It could also be the Nvidia drivers your using, people reported problems with some versions. Try upgrading.
Depending on the number of GPUs you have, this may take a while (several minutes). This will only happen the first time after the installation.
Ok, I will try, dont remember that from previous version.
