Vray_3.7 Fix light spots during rendering
Can someone please help me , as seen in the picture i have a light band that is bordered and shines down. but unfortunately it shines up through the element. i don’t know where i can correct it in the rendersettings anymore. Somewhere in the GI or ? Please help
THX
If you share the scene I can check that for you, I just need the essential to reproduce the issue.
Hi Sirio
Is it ok if I send it to you at this address: info@3dtutorialandbeyond.com ?
Scene received, I’ll check it out in the afternoon;)
Hello @alex_obrist
Can you please provide me with the scene file along with all associated assets so we can also investigate the issue?
If you prefer to not upload the scene publicly on the forum, you can open a ticket via our contact form and mention this forum thread.
Hello @alex_obrist
The issue with the light bleed was due to the Irradiance map. There are a few ways you can resolve the issue.
So far the easiest way is to enable to detail enhancement of the irradiance map under Global Illumination > Irradiance map> Detail Enhancement.
Another way to solve the issue is to switch the primary Global Illumination engine to Brute Force. That will generate the most accurate lighting result, as V-Ray will trace the primary lighting rays. However, this will increase the render time and I found it to produce a noisier image overall.
You can deal with the noise by increasing the bucket sampler max subdivision and lowering the threshold value, which can additionally increase the render time. A simpler solution would be increasing the radius value of the Antialiasing Filter. That will help with the noise but can blur your image a bit. I found out that a value of 2 works well.
You can find more information about the GI engines on the following articles: V-Ray for Cinema 4D
Brute Force: https://docs.chaosgroup.com/display/VC4D/Brute+Force+GI
Light Cache: V-Ray for Cinema 4D
Many thanks for the help Valentin !
Hi I’ve answered to your email;)
