Vray 5, Cinema 4d, Isometric View render
Hello, is there a way to render a isometric view in cinem 4d using Vray 5 render??
Hi Walter,
you can delete the Vray physical camera tag and use a standard Cinema4D camera, then it should work. Notice that the standard camera won’t have a proper exposure when dealing with Vray lights intensity so you will need to 1) tune your lights accordingly or 2) activate the auto exposure option from the override tab inside the Vray render settings.
That’s a pretty good tip, sirio76!
Do correct me if I’m wrong - you can also use a V-Ray 5 Physical Camera Camera and change the Object / Focal Length to 300 “Super Tele (300 mm)” . Though I’m not 100% sure if this is true isometric
It is a good and close workaround but not true isometric. If you try to render an isometric camera without the physical camera tag as Sirio suggested you will end up with e warning that informs that this camera isn’t supported and the rendering won’t start at all. I’ll discuss this with the devs and check what could be done about this. I’ll update the post when I have more information.
axonometrics are possibe in vray 5,without tricks:
if you go to rendersettings/camera/ orthogonal vray renders an axonometric view (isometrich IS an axonomatric view),
only in a certain angle which you can set also manually easy.
Either way I think it will be best for everyone if we make it work directly from the camera or per camera overrides since it will have a visual representation within the viewport and could be used in multiple cameras.
Thanks, this will help
“Either way I think it will be best for everyone if we make it work directly from the camera or per camera overrides since it will have a visual representation within the viewport and could be used in multiple cameras.”
yes would ne good
Hi - any news on easily setting up Isometric / Paralell view along with true editor camera preview?
I requested this feature months ago from the development team, they told me it was on the to-do list but not a priority. They pointed out to me that this is normal behavior of vray and the physical camera, it seems to me that it works like this also with 3ds max and maya
Hi at all, is there any update to this issue? Would be great, since I need a solution. Otherwise I would have to switch to another renderer for this job.
Hello @simon_eugster ,
We haven’t yet added support for Isometric Camera in V-Ray for Cinema4D. This is on our to-do list and we will let you know once this is done. Thanks for your understanding.
In order to correctly match the viewport with the rendering you will need to delete the V-Ray Physical camera tag.
Thank you Aleksandar for your answer. Works perfectly now!
