Vray 5 Lens effect only as render element
how to save Glare render pass without merging it with the beauty pass? In previous versions there was an option for it in the render elements dialog. Now with the new frame buffer I can’t find .
If you save the image with all render elements (either in separate files or a single multi-channel file), you will get a file with the original image there, as well as the glare element itself and the final effects result.
