Did the downloads section get moved? All I see under the support builds section are the RC4 Demos. Thanx
You are probably using the wrong login; if you can’t remember the correct one, you can email to vray@chaosgroup.com and we’ll find it for you. The login that you have to use is normally included in the email that you get when you purchase V-Ray.
just emailed ya
Thanx
Eric
