So there seems to be a Vray-specific issue when baking textures (I tried same setup in Arnold and everything works as expected there.) Also, perhaps this issue has been fixed in newer updates, but I still want to mention the issue just in case:
In a nutshell it seems like Vray does not respect manual Color Conversion settings when baking material elements via Bake To Texture with OCIO active as Color Management system.
Here is my setup.
Two VrayMtl with two texture inputs, one being an sRGB texture (set to load as such) while the other is a linear, set to load as Raw. They are both just connected to Diffuse.
Here are my global OCIO settings, specifically set to give the same visual appearance in viewports, material previews like the legacy Gamma Workflow:
In Bake To Textures I create two bake elements where I override Color Conversion on both, the sRGB one with identical settings as the global Render Output Defaults:
while the Raw is set to Raw:
What I expect here is that the output textures should look exactly as the original input textures. Same visual appearance with same colour values.
However with the setup described above I find that the Raw texture is not output the same as the original, despite my manual Color Conversion override:
If I change the global setting from Un-Tone-Mapped to Raw I get the opposite result, the sRGB is wrong, but the Raw is correct:
To me this appears like the Vray version I am currently using does not respect the manual Color Conversion override settings for bake elements, it seems it will always use the global settings no matter what. Again, this issue does not happen with Arnold so it seems to be Vray specific.
Has this been fixed in later versions than the one I am using or might this still be an issue even in the latest version?
