vray aerial perspective altering multimatte saturation
I’ve been using the aerial perspective and I noticed it seems to be writing to the multimatte as well thereby altering the saturation of the rgb.
thanks,
V Miller
You are right, thanks for the pointer !
Apparently, after a talk with our developers, this is the way it should work.
Would you have to do something like divide your multimatte passes by the alpha of an aerial perspective element then to restore their full strength?
It’s often a bit of a tricky one - how do you retain flexibility with semi transparent objects like fog or haze when compositing. In some ways I’d love to have an option for aerial perspective and fog that you can choose to have it as an element only - the solid parts of the render don’t have any of their elements affected by the atmosphere and we get our fog as a separate layer. It wouldn’t be as correct but might be handier for comping after.
Having masks affected by that effect is nonsense to me. If it is intended, it’s not good in my opinion. I need full strength normal masks. If I wanna do fancy stuff with it then this is post and shouldn’t be already done in the rendering, except as togglable option.
+1
I really wish multimattes were not affected. Can someone explain why it is the intended behavior currently? What is the benefit of this?
Like in some ways it makes sense since the pixels are made up of a percentage of the solid object and a percentage of the haze in front of it. In terms of what you’d do with the mattes and passes after though it’s not as helpful.
I prefer my multimattes to be clean
Why is that? You will get the same “issue” if there is a semi-transparent object in front of the multimatte; it is also because of this behavior that the mattes work correctly if there are opacity-mapped objects in front of them - you don’t have any objections to that?
I see your point there Vlado. I’m sure this is a potential problem for a number of users out there. Semi-transparent opacity maps are fairly rare in my workflow these days, but I’m sure this is not the case for everyone. I’m pretty much always rebuilding the beauty from AOV’s, and environment fog is used in almost every scene at this point. I’m doing all my tweaks using the multimattes on specific AOV’s prior to layering on the environment fog. So having the multimattes affected by the fog is not helping. Is it out of the realm of possibility to give us a checkbox to enable/disable the fogs affect on multimattes?
Tim J
Unfortunately it is; it is very hard for me to make an effect like that work on some arbitrary render elements but not others. If this behavior is not wanted, it would be best to render the aerial perspective on a separate pass.
The problem is if you render the fog separate then it won’t show up in reflective objects in the main beauty render. So instead I end up rendering my multimattes separate from the beauty render.
Tim J
That one is easy, we are adding an option to not affect camera rays (but still appear in reflections and refractions)
We really need to get a thanks function on the forum to replace redundant posts like this one :smile:
Same issue. Need clean multimattes or a way to hide Aerial from camera rays but still show up in atmosphere - is that possible?
Regards
Dariusz
Sorry for double post but here is a little more expanded reasoning why I need either clean multi matte or atmosphere not visible in render but still available in atmosphere render element.
1. If we do any heavy RAW color correction and are repalcing diffuse passes/etc/etc. We can not get clear selection of object.
2. If we decide to do heavy adjustment to Aerial and push it away from some objects we can not then regain full control over these objects due to matte issues.
3. If we have large objects - land and want to adjust color our adjustment curve will decrease the further the land is from us and we will have colo miss match + simmilar issues to point 2. Near us well have 100% affect, but far away we can get 20%, If we decrease atmosphere by 50% in post then we have no way of increasing the mask power by 50% in far away distance.
4. If we want to re-render the animation job then. A we either render it 2x. So a 4h frame render now turns up to 4h frame render + 2h mask render + mask will have different AA noise patern risking errors.
5. Creating 1 pass for atmosphere and 1 with hidden atmosphere wont work. We will end up in 2x long render times. And nope I dont think changing materials will work. Any glass material will produce errors and if I have 500 materials in scene then well… - also displacememnts will be a major issue…
6. Post artist give me angry looks.
Its awesome tool but unless we can get clean pass then… never gonna use it.
We are able to get light/reflection/other passes without Atmosphere affecting them… how come Masks are different?
Regards
Dariusz
