Vray altering custom render output
Hi guys, I need to render all my images at 3800 x 2133. If I change the custom output to these specs (which all my files are) If I close and re-open the file and render, the ratio instantly reverts to 3799 x 2133. So basically if I forget to go back into setting prior to re-rendering a saved file it dops one pixel. This is not a massive problem, just a niggle when it comes to post production. Would anyone know why this may be happening?
Thanks in advance,
Nick
Hello @AMG445 ,
Thank you for bringing this issue to our attention. Please note that it is logged internally under WEBUI-7014 and I have linked your forum post to it, so you will be notified if there is a change.
For the meantime please consider using the default 16:9 aspect ratio, in this case you will get 3800 x 2138 resolution and it will not be altered after the restart.
No problem at all - thanks for the reply, Cheers, Nick
