I have to render quite small rooms (such as bathrooms) and I would like to use a realistic focal length.
In the new version of vray for rhino there is the “vray clipping plane”.
However, once activated I would need the lighting to remain that of the entire model and not enter the “cut” of the clipping plane.
The Clipping plane (it is a rhino feature actually) literraly cuts snd removes geometry. It is for all rays - light, shadow, camera, etc.
you will need a camera near clipping, which only affects camera rays. Unfortunately there is no such feature in Rhino (although it exists in the SDK), so we don’t have UI for it out of the box. You will need to activate it with a short script
Check this post for details:
[https://forums.chaos.com/forum/v-ray...ng-not-working](https://forums.chaos.com/forum/v-ray-for-rhino-forums/v-ray-for-rhino-bugs/1051005-camera-clipping-not-working)
I wonder about the answer by Nikolay, maybe I misunderstood the initial question but for me, like I understand the question, the solution would be to add a Rhino clipping plane and adjust the options at the V-Ray asset editor like at the screenshot. So, geometry is clipped but the lighting situation is kept.
