Is it normal that while DR on a scene that has a high quality settings, that nodes start to render after a long time (a better part of an hour)?
I see in my V-Ray message window that the scene is loaded and all the nodes are starting frame, but then nothing happens (i.e. only the main station is rendering) for quite a long time.
So is this normal, because I thought that as soon as all the assets are downloaded from network the nodes should start to render, no?
Won’t that mean that my main station won’t render? I want it to render also, is just that the nodes start rendering really late. Maybe is this particular scene, but what is strange is, is that it was working fine before even on this scene..
oh, ok.
Well I did a regeion test render and after half an hour it was still on phase prepas 1, but I didn’t see any buckets or anything, so I canceled it. In message window it said the scene was loaded on all nodes though.
Ok, I’ll need a bit more information; if this always happens in this scene, can you send it to support@chaosgroup.com so that we can check what’s wrong? If it’s not possible, can you get me the V-Ray log file from one of the render servers while it is stuck?
I think it has to do something with vray displace mod. As soon as I turned it off, my nodes started to render a lot quicker. So I guess it probably is a RAM issue.
I have 10 nodes + my workstation and I see this behavior a lot even when not using displacement. When I have the DR machines render alone on a small scene using less than 5 gigs of ram the prepass stage takes a very long time. It will sit there for about 2.5 minutes before the prepass progress bar shows any progress, once the progress begins it goes very quickly and the rendering starts immediately after that. It seems like it’s taking a long time for the nodes to begin calculating the prepass, I thought it might be because it was taking a long time to load but watching the network activity that doesn’t seem to be the case. The scene I’m talking about only has about 600K poly’s with about 500 mb of maps and no displacement.
Old thread I know, but it’s exactly my problem.
When I enable displacement the nodes come to life only after a very long time. Is there some known solution?
I’m using V-Ray 2.00.26563 for Rhino…
Does the issue occur on every scene or just on particular one/ones.
What is the Cpu and Ram usage of the render nodes before their buckets appears in the frame buffer?
Is there any difference if you decrease the displacement settings?
The RAM was maxed out on all nodes, they started to page to disk.
I tried every setting related to displacement but it did nothing. After a general reset of all the settings, I was able to complete the render and now it renders fine. Frustrating that I can’t know what was the culprit this way…
