Vray does ingnoe USD instances.
Are instances supported for USD?
I have a file here that wont work like expected.
I cant upload it here please give me a mail so i can send the file over.
This should be fixed in the latest stable nightly build. Try it out.
Thanks i give it a try tomorrow.
Doesnt fix the issue.
V-Ray 5 for Maya, update 2.2 (v5.20.02, revision 31179 from Dec 22 2021)
Best you send us the scene along with the .usd and its instance so we can take a look. Mention me and include a link to this thread.
Filled a bug. #16770
But i forgot to add the USD instance. Is there a way to add a file later to the bug ID?
Send it again, I’ll close the other one.
Done. Thanks for looking into!
Thanks for the provided files. How was the geometry instanced? nParticles and Instancer?
With Bifrost. But this version is not available to the public.
Okay, I see. Just so you know, I’ve logged the issue (internal bug-tracker id: VMAYA-10965) for investigation.
Thanks!
Do you see the scattered robots in the viewport? Just to make sure the setup does work.
Some extra info.
The file is created with Maya_USD 0.15
Yes, they are visible in the viewport, but not when rendering.
Thank you, I’ll add it to the log.
