Hi were getting the following error on our renderfarm with vray for maya 2014
we’vetried reinstalling, checked the env variables where we found minor differences in back and forward slashes
I don’t think an official release will be any different - V-Ray will still look for that environment variable and it must be defined correctly.
How do you run mayabatch? From backburner, some renderfarm software or something else? Does it run as a service or as a normal user? In both cases, are the V-Ray environment variables correctly set for that user?
How do start the mayabatch.exe? Are you sure these tool that starts mayabatch.exe has the same env and preserves it?
Have you logged out and then logged in after you’ve installed maya. Sometimes these to operations are needed in order to get a working installation.
