vRay Environmental Fog - fallof problem
I have problem with vRay Fog: How to apply falloff for sphere gizmo (density on the edge)?
You can use a Falloff map in distance blend mode from the gizmo.
Thanks Vlad! Working good!
I’ve tried to replicate this but I don’t know where to find that “distance blend” Vlado refers there. Is it the density texture slot?
Vlado means put a falloff map - set to distance blend - in the density slot of the fog.
I have two follow on questions :
1.When apply the distant blend what mapping type should you use say for a sphere ?
2.If you are creating lets say a cloud and are using the distance map to control the density how do you do also create a rough edged cloud shape
If anybody has some nice cloud examples with settings they’d care to share, I’d love to see them
Thanks as always
Adam
There are some examples in the help index, but I suppose you have already seen those:
ooh, I wish these scenes were max9! :mrgreen:
Thanks for the reminder, I saw these examples while back but completely forgot about them, tehre also seems to be better examples now, I’ll spend a bit of time and got through these to get a handle on what I’m doing - I so often go off half cocked with my experimentation, I suppose the best thing to do is to recreate them and go through one by one - of course if they where already created for me somewhere in max 9 … nah that would be too easy
I’ll get my receptionist to hold all my calls - I’ve a fun afternoon ahead of me :]
not to sure if this is the best place for general environmental fog questions but can two fogs interact. for instance, if i do some clouds with the fog. then use another fog just for haze. would i get to see the “god rays” or whatever other people call them (the volumetric light) shinning through the breaks in the clouds?
Currently two atmospherics will not blend properly; we will be working on this for the next builds. It may be possible to achieve this with suitable textures, but it would be quite tricky.
i guess some form of a gradient to seperate the lower level fog from the upper level clouds might work
Back to the “Rough edges” question, is there a way to get this, Afterburn style?
All the test I have done (not many!!) have awsome volumetric noise, but then cut out of a sphere (or box). I have used the falloff, but it just faeds out that effect. You almost need a falloff that does it with noise rather than a uniform fade. See below. Top one Vray, bottom AB.
You can use a Falloff map in distance blend mode from the gizmo center to control the edge softness. You can combine this with the noise in a number of ways to get different effects.
I have tried that vlado, but cant seem to get the right look :frowning: It just fades off the noise so you get a blurry look.
Well it depends on what you do with it; you can for example do stuff like this. It was done by adding a falloff to the noise and clamping the result so that it is not negative.
That looks great Vlado! Could you post the scene for that? Im still having trouble getting that look. Using a Falloff with a noise in the white channel of the falloff and checking clamp in the falloff
edit: Oh, i see now, you used the output curve to clamp the falloff! Cheers!
