Vray Fb
A small request,
To be able to load a render back into the frame buffer, for easy color correction..
Agree. ---
Damn that was quick Sascha :stuck_out_tongue:
YEAHimthedamnquickmasterquickfinger!!! :wink:
lol .. thought so ..
the history option gives you this doesn’t it?
You can re-load previously saved VRIMG files
Yep, the history option does this
Ah yes of course it does..
thanks guys.. no need for this wish then ! .. Although not quite what i meant..
As a monkey grip you can copy EXRs to the folder you selected in the hostory (or select a different folder) to load them if i recall right.
Regards,
Thorsten
This history is part of SP3?
it’s been there for quite a while. it’s a hidden feature, you need to add a system variable to make it visible in the vray fb.
VRAY_VFB_HISTORY
value: 1
Okay…
This is not a MaxScript-line.
…do I do this in the 3dsmax.ini?
Thanks.
It’s an Environment variable
as in a Window’s environment variable…
:face_with_spiral_eyes: - hihi, okay - a little hint? Where do I set this system-variable? Never did it before. Registry?
Windows Control-Panel → System → advanced
then there’s a button at the lower end ‘environment variables’
Found this :smile:
http://www.vray.info/topics/t0123.asp
Or run this at a command line prompt :
setx VRAY_VFB_HISTORY “1”
(setx is part of XP sp2)
Regards,
Thorsten
:stuck_out_tongue:
WORKS - yeah, my friends, thankyouverymuchwhatabeautyfulhistoryIgobacktowork :wink:
Flipping heck … (means Damn in American) Perfect.. never knew this existed, why was it hidden ?
