vray for skp 7; environment
i have just downloaded vray for skp 7, and in trying to setup the options for a scene, i realised that the gi option is completely greyed out and i cannot click on it. Why is this?
It leaves my scene completely pitch black in the final render.
How do i solve this?
Re: vray for skp 7; environment
Under Indirect illumination menu turn On the GI.
thank you so much 40th now that the answer is that simple i feel kinda dumb for askin.
butt and mines kinda big :stuck_out_tongue:
Now i can see wat i’m rendering but the background is still black
what do i do now?
I recommend you restore the settings to default and continue from there.
To load the default settings:
In VfSU material editor window, File > restore defaults
in the material editor window there’s no file option :-[
i found file in the options window and i restored default settings however the gi is turned off again
Correct. If you want your background to be vray sky (instead of black), set your background type to Sky.
thank you
