I’ve tried this trick:
setAttr “vraySettings.vfbSettingsArr” -type Int32Array 0;
Which worked earlier this morning.
I tried deleting some nonesense in the .ma file.
I deleted my prefs
I restarted maya, and my computer.
I unloaded and reloaded vray.
I reinstalled vray.
This happens even if I just start maya and create a cube and try to render it.
I’m on vray 3.4.06 I think. Maya 2017
I still cannot see my frame buffer. Until I can, I can’t do much.
Ok. So I’ve figured out the problem…but do not have a solution.
After pulling my hair out for literally hours trying to figure out what is wrong, someone suggested plugging in a second monitor. I did. And lo and behold, there the vray frame buffer window sat like it had always been there. I moved it back onto my primary window and restarted maya. Renders to my second monitor. A monitor I didn’t even have until the frame buffer went missing.
How can I fix this? Is there a way to specify what monitor you want your frame buffer rendering to?
There is a weird workaround that I’m using in the meantime. I click the “Show vray frame buffer” button and while it has focus and before I click anything else I hold down the windows key and then press the left arrow three times and that’ll move it back onto my screen. But this isn’t a great way to work.
Any other ideas would be appreciated.
One cause of this happening is when you go from a 4k monitor to a 1k. A way to avoid it completely is to not use a floating window, but have it docked in Maya. Not sure if the VFB can do that.
Code:
for ($window in `lsUI -windows`) { if (`window -q -exists $window`==0) continue; if (`window -q -mainWindow $window`!=0) continue; window -e -tlc 0 0 $window; }
this is now implemented as a VFB functionality in the latest official builds. Right click on the VFB icon > Reset VFB position
you can dock the VFB in a viewport space: Panels>Panel>V-Ray Frame Buffer
Is this in latest nightly? I am on the latest official build and couldn’t see this option in my Panels>Panel menu in Maya 2017 Update 3.
Unfortunately this feature is not available in Maya 2017
At some point we added this mel function: vrayResetVFBPosition; and it should work for both maya versions where we have a panel and ones where we don’t.
Apart from mel, you can also access it by right clicking the VFB icon in the VRay Shelf.
