is this a bug? when i render an image with the maxscript render() command while having the vray framebuffer turned on the images rendered are completely black (no object, only the background). strange thing - any workaround for this?
You need to use the “Split render channels” option in the VFB if you want the final image to be saved. Another option is to just put any name as image output in the Render Scene dialog.
hey vlado, works for me. thanks for the hint!
