Just a small issue, when I change switch material over-ride on or off, RT refreshes but does not register the change in materials.
This is for the override material of the standard V-Ray renderer, right?
Hi Vlado,
Yes, that’s right. If I close and reopen the activeshade window, then RT does use the correct override setting.
I’m also getting override problems and errors.
The RT override check-box does not respond, you need to close the active window and restart it. I tried this a couple of times as the Override Exclude doesn’t seem to register.
I then got a RT crash:-
error:Unrecoverable error has happened during the last V-ray RT session.
Please, restart 3ds Max to continue using V-ray RT.
Did that, then tried turning the override on and off again, restarting the activeshade window between attempts…it crashed again, same error.
The vray standard Override Exclude doesn’t seem to work either.
Max2009 DesignSp1 | Vray 1.5sp3a | RT1.50.01 | XPpro sp2 x86
the “override exclude” seems to work okay now…I may not have put anything in the list ![]()
But I still get an "error:Unrecoverable error has happened during the last V-ray RT session.
Please, restart 3ds Max to continue using V-ray RT." when converting a perspective window to active shade and then opening and closing the active shade window toggling the RT override switch.
Still I’m glad the exclude override is working as that was my main concern ![]()
I’m experiencing similar issue playing with with the environment override, I’m trying to reproduce the error, till now, no luck ![]()
There were some problems with the normal V-Ray override; these should be fixed for the next update.
