Vray gpu 6, distance texture with vray fur
Hi Konstantin
Do you remember when i wrote about the chairs on a tapestry with vray fur.
Can i use distance texture over the vray fur just to take off that part of the chair, so i dont see vray fur with the wood chair??
Is this possible with distance texture and vray fur???
This is possible. Did you try it?
OK, no i havent tested, i would like to see first a tutorial from chaos group then match the workflow from my own.
Also i would like to see more things for vray gpu, to try Hard vray 6.
Ah ok, I see.
The Distance texture can be used in this case, yes.
Here’s a simple example:
In this case I’ve used a curve remap to change the Distance map’s falloff and.
The distance is then connected to the Density parameter of the fur.
Konstantin
Hi Konstantin
Thanks for your example, distance texture is going to be usefull for tapestries, i use skatter 2 for gardens, but for interiors i use vray fur with vray hair material.
I really liked the update 1 for 3d max, i hope we can see so many features that already works with vray for 3d Max to vray for sketchup.
