Vray GPU not working
My V-Ray GPU is not working properly, only works in CPU. If I try CUDA or RTX I get this error (First Image).
Default Settings, only changed the resolution and bucket mode. Using Rtx 2080, Maya 2020 and V-Ray latest version.
I did some tests in V-ray with 3ds Max and both modes are working fine.
Cheers,
Lucas
It seems like an exposure issue. Could you send the scene to support@chaosgroup.com so we can take a look? Mention this thread in the e-mail.
Thank you for sharing the scene. Is there any particular reason why you have overridden the environments with the Sky that you already have set in the scene? Or that was just testing? This seems to confuse the GPU engine and produce that effect.
Yes, you are correct VRaySky automatically overrides the environment slots. This turns out to be the scene unit issue. I’ll log it under VGPU-4847. To work around it you should set your Working units to centimeters.
Yes, know it’s working! Thanks
