I tested a scene with lens effects enabled and RT GPU as production renderer. When rendered first, glare and bloom worked well when enabled the lens effects dialogue in the vfb. Then rendered once again, and lens effects doesn´t work. The lensEffectsSource channel stayed empty. Restarting Max - no success. Restarting the whole PC, all works fine again, but rendered a second one it fails.
Any anwers?
My specs: Max 2014, vray 3.0
Sorry I meant in general, currently the lens effects doesn’t work with material ID and Object ID for production. Not sure about RT as I never tested it. I did speak to Vlado about it in a different thread so I wondered if the patch included the fix. - Chaos Forums
