VRay LensEffect needs to recalculate the whole image !
Hello everyone :slight_smile:
I have a problem when using VRay Lens Effects: I turn it On, and turn “Bloom” and “Glare” Off (to have a clean of any effect render). Once the render is done, I turn “Bloom” On and then click on the “Update Effect” as shown in Vlado’s Youtube Video … and the renderer starts all the job again ! (Irr map, Light cache …). I have to mention here that VRay Lens Effects works fine with a complete new scene, and that this problem only happens when used with an old mental ray scene, converted into vray scene using the “vrayscene converter” option.
Anyone can help me please ? :face_with_spiral_eyes:
Thank you a lot :slight_smile:
Can you get me the scene where it does not work to vlado@chaosgroup.com ?
I restarted max and now it works :sunglasses:
I do also have the problem but only sometimes… I don’t know what triggers vray to just redo the bloom and glare and not the whole image.
I have this problem too sometimes.
And sometimes after calculating lens effects rendered images gets brighter but effect didnt show up. But only sometimes too.
Is it possible that in the meantime you have accidentally done changes to the scene (e.g. changing some geometry, or a parameter value somewhere, or selecting objects etc)?
I do have sometimes the same problem hapenning: before rendering, I first set a “VRay Lens Effects” in the “Environment and Effects” Tab and check it is active. I set both “Glare” and “Bloom” inactive. I hit render. When it’s done, I activate “Glare” and click on “Update Effect”: the effect shows up on the render window, that’s fine. But, sometimes, at this point, when I deactivate “Glare” and click on “Update Effect” again, the effect doesn’t go off … And when I activate it and update the effect again, the image gets even brighter just as said Jiri.Matys :face_with_spiral_eyes: I didn’t have the time to do a lot of tests. It only happened sometimes.
I didn’t make changes. I hit “update Effect”, it renders the image again and from then on it works.
i get this problem constantly!!!
Lens effects active, applies the effect upon render end.
after that i hit update effect (checking interactive or not doesnt matter)
and it starts recalculating the whole image!
Drives me nuts…its completely useless…i get it with every scene..no matter if i restart max or not..:-/
Is there any update on this bug?
Thanks for info
Me too think it is useless: I stopped using it.
It is strange because some users seem to use it without any problems …
It would be nice to have a ChaosGroup feedback about it.
I have this problem too. I find out, first open the effect tab where lens effects are. Click on it to see the parameters, dont change anything. Now hit F9, render a frame and now change anything from previous opened effects tab. It works.
pfff…sorry to say this but this sort of functionality is really weird (thats being said really nicely)
good tip Jirko!!! Thanks!
anyway…i really hope this gets fixed soon
Thank you for the tip Jiri.Matys. I have to try it like you say.
You are welcome. I spent all day to find out this little trick, glad to help.
anyway…
since one can now load vrayimg back into VFB, shouldnt one be able to use the effects without having to even load the scene???
I dont know how it works exactly, but maybe it use another information from the scene, not only how bright is the pixel, but the reflection, glossiness, dont know.
hello,
just wanted to point out that my scenes keep re-rendering too, i just can´t get them to update instead of doing that. this way the effects are kind of useless, at least to me, because you can´t do any tweaking without wasting half a day waiting for test-renders.
anyone using those lens effects without troubles? the tip of jiri didn´t work for me… or maybe i got it wrong, how did you do it exactly jiri?
any fix on this vlado?
best regards,
christoph.
you need to keep the effects tab open, this way youll be able to work on it interactively after rendering…this works for me
stil kinda sad the vrimg cant be loaded into vfb and apply the effects at any given time such as you can see that fryrender works …oh well…priority is elsewhere in vray (which i understand)…i guess we will have to either wait or do without :slight_smile:
thanks for the clearing up martin! but nope, this doesn´t work for me, i mean keeping the effects tab open… too bad! i have those tabs open almost all the time on my second monitor, but tried it once again to no avail after your tip. in my case it always seems to rerender the scene. maybe the next update, keeping fingers crossed as i would really love to use those effects.
best regards,
christoph.
hello vlado,
any chance there´s a build of vray 2.0 coming that doesn´t rerender the scene if playing around with the lens effects? would be appreciated very much! :slight_smile:
best regards,
christoph.
