vray light material
any ideas on why an object with the vraylight material applied to it will not “light” it just stays dark
weird…
oops
sorry, wrong topic, oops
Will answer anyways. You got GI on ? The VRayLightMtl only emits GI, no direct light.
Regards,
Thorsten
live and learn
figured it out, secondary ray bias was 0, apparently this cannot work, made it .01 and they popped
problem solved, thanks
wich means you most likely got co-planar faces in there, wich is un-desirable
Regards,
Thorsten
thought i
did too but apparently i dont…
gonna try to see if the vray light material works in a blank scene without secondary ray bias on
