vray material viewport update issue
Hi
Vray latest version in 3ds max 2021 and 2022 won’t update immediately in viewport when updating material.
Hi are you talking about Viewport IPR? Could you share a video of the issue? If you have a lot of high-resolution textures it may be expected. How much is the delay?
Hi
I am talking about standard Viewport (not IPR). when changing diffuse color, reflection etc. the change update only after i move the viewport or making any change. it work fine in other render engines. also works fine in vray for 3ds max 2017.
Hi you are right it does have some strange behavior. I tested what you are describing and it happens on my end as well. Let me research a little further and get back to you.
Hi this issue is already reported and logged in our bug tracking system (VMAX-11983).
The issue affects only the compact material editor. Slate material editor updates instantly.
