vray mesh export dialog missing
Hi
I am not sure when it gone but it would be great to point me where I should look for in Customize User Interface (as I was not able to find it) to make a shortcut. I have fairly fresh 3ds max (2019)install and have tried to reinstall and install few different vray versions. Currently on latest V6. Thank you for your help.
Hi, thanks for posting. These commands were moved from quad menus to the main toolbar. Please check the image below.
Ok, missed that… Thank you!
But if I need to return as it was.
I call “Vray menu registration” and nothing works.
Only through “Custumize user interface” it turns out to set everything up.
Why is that?​
Because we changed it. And yes, manually adding them through the Customize User Interface menu is possible.
Hurry up =)
Isn’t it more logical to leave it all optional?
