"the warning : Material has unlocked highlight and reflection glossiness : this is no longer supported and will be ignored " = what does it mean ? and how to solve ?
thank you
It means that the old separate glossiness for specular and reflection is no more (the material UI ought to show this).
Solutions are dependent on shader setup: they may vary from simply copying the lowest glossiness/map of the two (the old parameter still exists, accessible through maxscript) into the reflection, to creating a layered shader with one glossiness value/map each.
Unfortunately, this isn’t something easily solvable on our side (to get a 1:1 result, that is), as users’ intent when using this option has been varied in the past, and each shader may wish for a different treatment, one which only the original shader creator may know (cfr. very old evermotion stuff.).
just buy VMC, u can disable from scene all highlight lock
I’d advise against doing that, if the image looks are to be preserved.
Otherwise, hey, as i said, all it takes is three lines of maxscript (which i have and use daily.) and goodbye to separate glossiness values (and along with those, the original shader look.).
thank you,
can you share this script ?
Yes, this is precisely what you shouldn’t do.
Along with that, you also removed all and any specular glossiness mapping, and a bi-layer look to your shader.
As a result, the image before, and after, the treatment (or before and after the beta of Next) will not look the same.
It may be good enough for you, but it’s not something we can force on users.
Still, without further ado, here’s the oneliner to turn those off (i shall take no yelling for this, though…):
for m in getclassinstances vrayMtl do m.reflection_lockGlossiness = true
Remember: you will lose specular highlights this way, if they were set up with a sharp reflection and a glossy spec, and all and any of the mapping done to the specular channel. (it’s still in the shader, though, just not in the UI).
I keep getting the specular, nothing change, but if u say, cool. cheers
hi, sorry, just noticed this. I haven`t tried Vray 4 next because we can`t run betas. I can`t quite tell what the situation is above. Are the separate controls for highlight glossy and reflection glossy being removed going forward ?
Yes. To make room for nicer things. ![]()
You do, because in your example your reflection glossiness is lower than 1.0.
You have still lost whatever parameter/texture was previously setting the Specular glossiness (as one would with my script line above.), along with that part of the effect.
To do it exactly right, one would need to split the original shader in two, a base with the reflection, and a layer for specular -as it was named-, and *add* the two together.
That however would require generating a new blend shader, meaning sampling, and memory usage, will be slightly different than with the single shader, and in additive mode one would risk breaking energy preservation if done improperly (the sum of the layers in additive mode isn’t checked for reciprocity and could well reflect more light than it receives.).
Glad to see it go tbh; never once unlinked the two in ten years - though had many purchased assets with strange setups where they were.
Seconded..
Good riddance, I’ve seen colleagues of mine that still use this, takes me a lot of clicking and changing the shaders when I have to work on their scene. Now that they won’t be able to use this anymore it will mean less frustration for me ![]()
Back a million years ago, it kinda made sense.
It’s high-time for a Meteor, though. ![]()
Hi there,
I’m testing with Vray Next, I also purchased the VNC plugin/script but can’t get it to launch.
Anyone with Vray Next working with this VNC?
Works for me
Ok, thanks, I’ll get back in touch with the support from VNC
Hi there,
Just to correct something here: I meant VMC: VrayMtl Converter (3) - MAXTools: V-RayMax Converter PRO
Did you mean: VMC as Vray material control?
VMC just stopped working for me, too. Strange, because it worked fine since my earlier post. All the links to the script seem to be dead, too.
The site is back up and so is my script.
