I have a problem with vray next, if I use a multiscatter object vray next crashes, vray next GPU goes without problems…
vraylog.txt (176 KB)
I think your multiscatter does not support Vray Next.
I got the same error with Forest Pro Beta version (Suppose to support Vray Next?). If I deleted the Forest objects, the scene would render.
So have to wait for an offical build that does support Vray Next.
when you install multiscatter you can choose vray next, and on the official site they say it support vray next. Vray next gpu works fine…
Delete the scatter objects and if scene renders, you know the problem. Saw on Itoo forums a guy saying multiscatter giving him same error.
thank you!!
Solved! It was the version of multiscatter, they sent me a different version and everything works.
