VRay NEXT for Maya 2018 trial - NO GPU rendering available.
I just downloaded and installed the Vray NEXT trial for Maya 2018. Suddenly GPU is not available in the VRay “Production engine” tab in the render settings, only CPU shows up. I had 3.6 installed and it was rendering fine with GPU and CPU. Is this a known problem?
Are you on Mac OS?
You will need to edit your Maya.env tab to unhide the Cuda engine
See here,
https://forums.chaosgroup.com/forum/v-ray-next-beta-for-maya/v-ray-next-beta-for-maya-general/1005976-deprecated-cuda-engine-on-macos-and-removed-it-from-the-ui
Thanks Muhammed - yes, I am on a Mac, and i recall doing that with my other install. I’ll try it out.
