VRay Next Trial- Error Message
I’m trying to do a basic test render using V-Ray Next trial on a scene and got the attached error msg. Any idea what it could be?
Thanks!
I just uninstalled the VRay Next Trial and and installed back VRay 3.60.04, which works fine (Thank God!).
For a second I thought it could be something with my computer.
Do you have any third party plugins like IToo ForestPack or RailClone - they need an updated version to work with V-Ray Next. If that is not the case - then when Max crashes it should create a crash dump called 3dsmax_minidump.dmp in your temp folder (%temp% in your windows explorer) - could you attach it here or send it to support?
Yavor
Hi Yavor,
I do not have the third party plugins you mentioned but I was using a frame buffer plugin called VFB 2.0. Do you think that could have caused the crashes?
I will attach the the crash dump here.
Thanks!
-Fausto.
Haven’t seen reports about it yet so I don’t know if this VFB is the problem. Dumps will give us a clue about it.
Yavor
Hi Yavor, I did a test and it seems to be VFB. I will attach the Dump file here soon
