I am doing a curse, but all scenes are on Max, and I would like to know what is similar to “vraycolor node” in cinema 4d?
I need parameters like: color mode, RGB multiplier, RGB primaries…" wich I can not find on C4D.
Hi, you can try Color Node if you are using V-Ray Node Space, or Color shader if you are using Classic Materials. Please let me know if this is what you’re looking for or if you need something different.
Hi Zhanet,
Many thanks for your reply.
Well I already tried all Color Nodes to find this “RGB primaries…Multiplier” didn’t found.
I honestly thought that Vray is the same every others softwares, but in Max is different.
So what I like is : RGB multiplier controls the intensity or brightness of a color within a material or light, adjust the overall color strength, making it brighter or darker without altering the hue or saturation.
Hi francisco_fernandes, you can pass the base color through a Color Correction node, and inside the Color Correction node, you can use the Brightness parameter to increase or decrease intensity, similar to an RGB multiplier.
Hi Zhanet, thank you so much. I will do that, I think that will work.
