Another V5 major issue - why and how to overcome the camera offset vs picture viewer? I’m of course using “pinhole” setting, which was working in 3.7 (using film offset).
If it’s not possible I’m reverting to 3.7.
You might think this is matching, but it can be slightly off - please try my file - did not install the latest update yet, wondering if it is corrected.
Hi @RwVision ,
I’ve bumped the issue with the camera, so we can look in to it soon.
BTW - why the Override tabs do not support different background Projection?! Like frontal is not possible like in 3.7
You can use the Cinema 4D Background object and apply a material to it. Then set the Projection on the material tag to Frontal.
We don’t yet have any updates to share. We will let you know as soon as we have more information. Thank you for your patience.
Does this solution fully work with matte comp tags and overrides color correction?
The Cinema4D Background object works well when using the Object Properties tag to create matte surfaces. Are you referring to the color corrections in the VFB2? Color corrections in the VFB2 will also affect the C4D background object.
The color mapping, set in the Render settings won’t be applied on the Cinema4D background object if the “Affect Background” is disabled. However, as mentioned here, this option is not supported when using the Progressive image sampler and will only work with the Bucket image sampler.
