Hello, I was having issues with Vray crashing Maya was receiving this error message “//ERROR V-RAY: There was a fatal error building the scene for V-RAY”. so from several crashes then i received this message // Error: Could not obtain an interface license (-200): The ChaosGroup License Server could not be reached. So i uninstalled Vray and deleted ChaosGroup folder from Common Files. Reinstalled Vray logged on everything installed successfully. I fired up Maya and and clicked on Plug-ins manager to load Vray but VRAY plug-in is missing. Not sure what to do and would like some help. Thanks in advance!
// Warning: file: C:/Users/Sergio/Documents/maya/2019/prefs/shelves/shelf_VRay.mel line 40: Pixmap file shelf_vray_proxy_create.png not found, using default. //
// Warning: file: C:/Users/Sergio/Documents/maya/2019/prefs/shelves/shelf_VRay.mel line 74: Pixmap file shelf_vray_proxy_import.png not found, using default. //
// Warning: file: C:/Users/Sergio/Documents/maya/2019/prefs/shelves/shelf_VRay.mel line 108: Pixmap file shelf_VRaySceneManager.png not found, using default. //
// Warning: file: C:/Users/Sergio/Documents/maya/2019/prefs/shelves/shelf_VRay.mel line 147: Pixmap file shelf_PluginNode.png not found, using default. //
// Warning: file: C:/Users/Sergio/Documents/maya/2019/prefs/shelves/shelf_VRay.mel line 181: Pixmap file shelf_vray_mtl_from_file.png not found, using default. //
// Warning: file: C:/Users/Sergio/Documents/maya/2019/prefs/shelves/shelf_VRay.mel line 215: Pixmap file render_VRayVRmatMtl.png not found, using default. //
// Warning: file: C:/Users/Sergio/Documents/maya/2019/prefs/shelves/shelf_VRay.mel line 249: Pixmap file shelf_StereoRig.png not found, using default. //
// Warning: file: C:/Users/Sergio/Documents/maya/2019/prefs/shelves/shelf_VRay.mel line 283: Pixmap file shelf_vray_metaball.png not found, using default. //
// Warning: file: C:/Users/Sergio/Documents/maya/2019/prefs/shelves/shelf_VRay.mel line 317: Pixmap file shelf_vray_volume_grid.png not found, using default. //
// Warning: file: C:/Users/Sergio/Documents/maya/2019/prefs/shelves/shelf_VRay.mel line 351: Pixmap file shelf_vray_plane.png not found, using default. //
// Warning: file: C:/Users/Sergio/Documents/maya/2019/prefs/shelves/shelf_VRay.mel line 385: Pixmap file render_VRaySphereFadeVolume.png not found, using default. //
// Warning: file: C:/Users/Sergio/Documents/maya/2019/prefs/shelves/shelf_VRay.mel line 420: Pixmap file shelf_vray_toon.png not found, using default. //
// Warning: file: C:/Users/Sergio/Documents/maya/2019/prefs/shelves/shelf_VRay.mel line 454: Pixmap file shelf_LightMeter.png not found, using default. //
// Warning: file: C:/Users/Sergio/Documents/maya/2019/prefs/shelves/shelf_VRay.mel line 489: Pixmap file shelf_Clipper.png not found, using default. //
// Warning: file: C:/Users/Sergio/Documents/maya/2019/prefs/shelves/shelf_VRay.mel line 528: Pixmap file shelf_VRayObjectProperties.png not found, using default. //
// Warning: file: C:/Users/Sergio/Documents/maya/2019/prefs/shelves/shelf_VRay.mel line 567: Pixmap file shelf_vray_light_mesh.png not found, using default. //
// Warning: file: C:/Users/Sergio/Documents/maya/2019/prefs/shelves/shelf_VRay.mel line 605: Pixmap file shelf_vray_fur.png not found, using default. //
// Warning: file: C:/Users/Sergio/Documents/maya/2019/prefs/shelves/shelf_VRay.mel line 644: Pixmap file shelf_VRayDisplacement.png not found, using default. //
// Warning: file: C:/Users/Sergio/Documents/maya/2019/prefs/shelves/shelf_VRay.mel line 683: Pixmap file shelf_vray_renderable_curves.png not found, using default. //
// Warning: file: C:/Users/Sergio/Documents/maya/2019/prefs/shelves/shelf_VRay.mel line 722: Pixmap file shelf_vray_nurbs_tesselation.png not found, using default. //
// Warning: file: C:/Users/Sergio/Documents/maya/2019/prefs/shelves/shelf_VRay.mel line 756: Pixmap file shelf_LightDome.png not found, using default. //
// Warning: file: C:/Users/Sergio/Documents/maya/2019/prefs/shelves/shelf_VRay.mel line 790: Pixmap file shelf_LightRect.png not found, using default. //
// Warning: file: C:/Users/Sergio/Documents/maya/2019/prefs/shelves/shelf_VRay.mel line 824: Pixmap file shelf_LightSphere.png not found, using default. //
// Warning: file: C:/Users/Sergio/Documents/maya/2019/prefs/shelves/shelf_VRay.mel line 858: Pixmap file shelf_LightIES.png not found, using default. //
// Warning: file: C:/Users/Sergio/Documents/maya/2019/prefs/shelves/shelf_VRay.mel line 894: Pixmap file shelf_LightSun.png not found, using default. //
// Warning: file: C:/Users/Sergio/Documents/maya/2019/prefs/shelves/shelf_VRay.mel line 930: Pixmap file shelf_texSky.png not found, using default. //
// Warning: file: C:/Users/Sergio/Documents/maya/2019/prefs/shelves/shelf_VRay.mel line 964: Pixmap file render_VRayMtl.png not found, using default. //
// Warning: file: C:/Users/Sergio/Documents/maya/2019/prefs/shelves/shelf_VRay.mel line 1021: Pixmap file shelf_materials.png not found, using default. //
// Warning: file: C:/Users/Sergio/Documents/maya/2019/prefs/shelves/shelf_VRay.mel line 1063: Pixmap file shelf_vray_texture_baking.png not found, using default. //
// Warning: file: C:/Users/Sergio/Documents/maya/2019/prefs/shelves/shelf_VRay.mel line 1099: Pixmap file shelf_show_vfb.png not found, using default. //
// Warning: file: C:/Users/Sergio/Documents/maya/2019/prefs/shelves/shelf_VRay.mel line 1133: Pixmap file shelf_vray_vrqs.png not found, using default. //
// Warning: file: C:/Users/Sergio/Documents/maya/2019/prefs/shelves/shelf_VRay.mel line 1167: Pixmap file shelf_LightLister.png not found, using default. //
// Warning: file: C:/Users/Sergio/Documents/maya/2019/prefs/shelves/shelf_VRay.mel line 1201: Pixmap file shelf_cloud_rendering.png not found, using default. //
// Warning: file: C:/Users/Sergio/Documents/maya/2019/prefs/shelves/shelf_VRay.mel line 1235: Pixmap file shelf_vray_help.png not found, using default. //
file -f -new;
// untitled //
commandPort -securityWarning -name commandportDefault;
onSetCurrentLayout “Modeling - Standard”;
// Warning: file: C:\Users\Sergio\Documents\maya\2019\prefs\filePathEditorRegistryPrefs.mel line 4: filePathEditor: Attribute ‘aiImage.filename’ is invalid or is not designated ‘usedAsFilename’. //
// Warning: file: C:\Users\Sergio\Documents\maya\2019\prefs\filePathEditorRegistryPrefs.mel line 5: filePathEditor: Attribute ‘aiPhotometricLight.aiFilename’ is invalid or is not designated ‘usedAsFilename’. //
// Warning: file: C:\Users\Sergio\Documents\maya\2019\prefs\filePathEditorRegistryPrefs.mel line 6: filePathEditor: Attribute ‘aiStandIn.dso’ is invalid or is not designated ‘usedAsFilename’. //
// Warning: file: C:\Users\Sergio\Documents\maya\2019\prefs\filePathEditorRegistryPrefs.mel line 7: filePathEditor: Attribute ‘aiVolume.filename’ is invalid or is not designated ‘usedAsFilename’. //
// AbcExport v1.0 using Alembic 1.7.5 (built Feb 6 2018 18:28:08)
evalDeferred “shaderBallRendererMenuUpdate”;
// Warning: line 1: filePathEditor: Attribute ‘aiStandIn.dso’ and label ‘Standin’ have been saved already. //
// Warning: line 1: filePathEditor: Attribute ‘aiVolume.filename’ and label ‘VDB’ have been saved already. //
// Warning: line 1: filePathEditor: Attribute ‘aiImage.filename’ and label ‘Image’ have been saved already. //
// Warning: line 1: filePathEditor: Attribute ‘aiPhotometricLight.aiFilename’ and label ‘IES’ have been saved already. //
import arnold
// Successfully imported python module ‘arnold’
import mtoa
// Successfully imported python module ‘mtoa’
import mtoa.cmds.registerArnoldRenderer;mtoa.cmds.registerArnoldRenderer.registerArnoldRenderer()
// Successfully registered renderer ‘arnold’
updateRenderOverride;
// Warning: file: C:/Program Files/Autodesk/Maya2019/scripts/startup/autoLoadPlugin.mel line 35: Loading plug-in “mtoa” has resulted in changes to the scene that may need to be saved. //
// AbcImport v1.0 using Alembic 1.7.5 (built Feb 6 2018 18:28:08)
updateRendererUI;
updateRendererUI;
