Vray RT ditches the composite textures when rendered with Production render option.
Has any one had this issue and if so any work around?
First image is correct using RT and the second is not correct using Production render for RT
Can you get us a scene for this to vray@chaosgroup.com ? Ideally it should work fine…
I will email it now. Also, if I switch from CUDA to OPENCL it still renders incorrectly but if I switch to CPU it renders the textures correctly.
