Hi. I work with light dome + Vray HDRI and tuning the scene with RT GPU.
When HDRI gamma is set to 1 everything works well - image1.
When i want to increase contrast of HDRI by changing HDRI gamma value
RT output goes completely wrong - image2.
Is this a bug or is this not implemented to RT yet?
I’ve had trouble with this as well. Actually, lately any RT renders don’t look at all like the regular ones. It worked fine in 1.5 but since then I haven’t had any luck with RT. People at work reporting the same thing… maybe a max/vray gamma problem? Not sure there.
Currently the RT engine applies the gamma and the multiplier in reverse order to the production renderer, which leads to these differences, and this is a known issue. This will be fixed, but in any case applying gamma to a HDR image doesn’t make much sense in the first place (since it’s supposed to be already in linear space).
@Deflaminis - I think you are talking about a different problem, since what Jozef describes has been like that even in the 1.5 builds.
