VRay RT rendering slow with many errors
Hello all,
My company just invested in a new computer to speed up my pipeline. I’ve got two Nvidia 1080 GTX cards that I’ve set to render with and a smaller one just for the display. But after multiple tests I’m getting better speeds just rendering off the CPU (Intel Xeon E3-1275 v5).
I custom ordered this build so I could work on other projects to free up the CPU though. I’ve tried PNG sequence and RT will layer the sequence ontop of one another. With Tiff sequence it just crashes after 3 frames. On top of everything else, the anti-aliasing appears inferior to the V-Ray Adv settings. I’ve attached an image below. Is there something I’m missing? GPU should be faster for animation, right?
Thanks in advance
-Mike
Hard to say without more data - host app, version, log, or if you the best will be to share the scene. It will be helpful if we can check here what is going on.
In the meantime, it might be good to check if you are using drivers > 380 and to downgrade to any that is 37X.
Best,
Blago.
Another piece of information that may be crucial. For the image sampler I’m doing selected objects only. This option works just fine in Vray ADV & is creating overlapping images like Vray RT.
I’m trying to render out a camera circling an object & I want the lighting information from the scene, but not the background.
Please can you confirm is using drivers >380 still a problem ? I have 1080 ti’s and am using drivers 382.05. In fact, my cards didn’t come with 370 drivers (so where would I get those ?).
I’m using 378.92 on my 1080 ti and 980. They work well for me so far. You can download them here: http://www.nvidia.com/download/driverResults.aspx/116346/en-us
