Hi!
Whenever I try to reset the Material Editor of 3DS Max 2011 Design with VRay SP5 I get the error you can find in the attachment.
Everything works fine with 3DS Max 2010 Design and SP4a.
The complete Script-PopUp looks like this:
-- MacroScript File
-- Created: Feb 09 2005
-- Last Modified: Feb 25 2005
-- Medit Utilities
-- Version: 3dsmax 8
-- Author: Alexander Esppeschit Bicalho, Discreet
-- Modified: Alexander Esppeschit Bicalho, Discreet
-- MODIFY THIS AT YOUR OWN RISK
/* History
Feb 09 - created script
Feb 10 - fixed problem where defaults.ini uses Hex number and ClassID is an Int
Feb 10 - added Restore Medit Slots script
Feb 11 - added Localization Notes
Feb 25 - added Condense Medit
Feb 25 - moved functions to meditfunctions.ms in StdScripts
NOTE TO LOCALIZATION
Only the headers should be localized
macroScript clear_medit_slots
enabledIn:#("MAX", "VIZ")
category:"Medit Tools"
internalCategory:"Medit Tools"
ButtonText:"Material-Editor-Felder zurücksetzen"
tooltip:"Material-Editor-Felder zurücksetzen"
on execute do
defaultMtlLibFile = MeditUtilities.getDefaultLibraryFile()
if defaultMtlLibFile != undefined do
defaultMtlLib = loadTempMaterialLibrary defaultMtlLibFile
global _meditMaterialsBeforeReset = #()
for i in 1 to meditMaterials.count do
append _meditMaterialsBeforeReset meditMaterials[i]
if i <= defaultMtlLib.count then
meditMaterials[i] = defaultMtlLib[i]
else
meditMaterials[i] = defaultMtlLib[defaultMtlLib.count]
macroScript restore_medit_slots
ButtonText:"Material-Editor-Felder wiederherstellen"
tooltip:"Material-Editor-Felder wiederherstellen"
on isEnabled do (if classof _meditMaterialsBeforeReset == Array do _meditMaterialsBeforeReset.count > 0)
on execute do
if _meditMaterialsBeforeReset.count == meditMaterials.count do
meditMaterials[i] = _meditMaterialsBeforeReset[i]
_meditMaterialsBeforeReset = undefined
macroScript condense_medit_slots
ButtonText:"Material-Editor-Felder komprimieren"
tooltip:"Material-Editor-Felder komprimieren"
on execute do
usedMtls = #()
if MeditUtilities.isMaterialInUse meditMaterials[i] == true do
append usedMtls meditMaterials[i]
if i <= usedMtls.count then
meditMaterials[i] = usedMtls[i]
else if i <= defaultMtlLib.count then
else
macroScript basic_material_editor
ButtonText:"Kompakter Material-Editor..."
tooltip:"Kompakter Material-Editor..."
on execute do
-- close sme if needed and open Medit
maxOps.mtlDlgMode = 0
if (sme.IsOpen()) do sme.Close()
-- Safe to call redundantly. Will restore window if minimized.
matEditor.Open()
macroScript advanced_material_editor
ButtonText:"Erweiterter Material-Editor..."
tooltip:"Erweiterter Material-Editor..."
on execute do
-- close Medit if needed and open sme
maxOps.mtlDlgMode = 1
if (matEditor.IsOpen()) do matEditor.Close()
sme.Open()
I reinstalled VRay SP5 a few times now.
What could be the reasen / what could be a solution?
Greetings and thanks!
