In the latest VRay 2.4.04 the scene convertor doesn’t convert Arch & Design materials. I remember that was changed in vrayutils.ms a while back but even after removing the commented line below it still leaves them as Arch&Design. I must be missing something basic. Anyone?
-- Do not convert Arch&Design materials - V-Ray supports them directly
Arch___Design__mi: convertFrom_ArchAndDesign orig_mtl
Yeah I blindly trusted the Scene Conventor on a quick job just this week and it ended up going all sorts of wrong when the Arc & Design materials threw hot pixels all over the place.
@ValeroStudio - actually that’s what I ended up doing. I use the Autodesk Material Converter typically for converting Revit materials but it worked in this case to convert Arch&Design to VRay as well… Bummer about that tool though is it breaks instanced materials so I had to go through with Instance Material by Name from Track Tools to fix that.
I still find it odd the VRay Scene Converter skips Arch & Design. I was poking around in the script itself and there is clearly functions for converting Arch & Design to VRay and I was able to utilize it one at a time. If I can get it working I’ll post the instructions.
ah just came across this problem
managed to find where to purchase it from via the developer posting on warez site of all places! :lol:
couldnt find a purchase link on his homepage…bit or an oversight on his behalf
