vRay SceneManager sequence impot
Hello everyone,
how can I import a animated vRay scene sequence?
I think I have to change the number after the name of the file in something like ´.####.vrscene´
But of cause this does not work. :slight_smile:
I hope someone can help me with this because I cannot produce it into one giant File.
Thanks in advance
You were close. You need to change the padding numbers with <frame04> (the number depends on the number of padding digits; i.e. a sequence with 4 digits, such as 0001, 0002, would be frame04; whereas a sequence with 3 digits, such as 001, 002, would be frame03).
