When I try to start the Vray Spawner for the 64bit version of Vray, running on Windows XP 64 for MAX 9 64, it won’t load the vraydummy(xx).max file.
It keeps trying to but instantly closes, over and over again.
On the same machine, the Max 8 Vray Spawner loads absolutly fine.
What could it be?..
is the render machine able to “see” a license?
Found it - it was my fault, a dodgy install of MAX 9
Just a tip - don’t install MAX 9 off the .msi files like you did with MAX 8!
EDIT___
However It is still not working and doing the same thing! How strange - the spawner on my local machine works fine…
SteveC
December 7, 2006, 9:32am
4
Hi atom,
Try running backburner manager and spawner once, on the machine with
the problem, this should fix it.
I had exactly the same problem, and did this and it worked ok after that.
steve
good tip there steve! i have finally been able to get DR going on my laptop!
I think you may be onto something there - however, I can’t even get backburner to work - I can’t uninstall it as it has an error and I can’t install the new version until the old one is removed! So frustrating!
Has anyone else encourtered this?
