Hi
When I use lightmix and light select render elements with sun and any mode selected I am getting always full mode results. Deleting lightmix and I have all passes from light select again. I am on vray 5. I hope it can be fixed as I love the lightmix flexibility but light select option are handy too.
Shall we expect fix for this? Thank you for reply
If you use any of the automatic groupings of LightMix - then we create Light Selects for the lights always in full mode and disable any manually created light selects. If you want to split the light selects then you need to use the manual mode and create the necessary Light selects.
Yavor
