Light Select
Does light select not work in VRAY 5? I use it on every job, have it as an element, but it isn’t in the VFB pulldown.
I guess lightmix is the new lightselect, but why is lightselect still there?
One may want to mix the lightselects in post.
BTW, I found that I can’t use LightMix with LightSelect created by my own. For example. I want to have LightMix and custom LightSelect with specific lights included and Light path expression. BTW, how can I achieve separate render element for 2 sided material effect where I see only light that go through 2 sided material??
This is when you fire up a Post software and do your thing. :slight_smile:
