Hi!
Is there any converter or simple kind of magic to change vray scene (bought on evermotion) to corona scene?
I have demo of corona render and if the render of my scene will be good = I’ll buy full ver. of Corona.
Anyone knows?
yep just look at script section on this forum…works very well
https://forum.corona-renderer.com/index.php/topic,126.0.html
You also already have a version pre-installed with Corona (in your max/scripts folder)
ok, i’ve found that but please, these are my first steps in 3dsmax, can You give me a hand on how to convert vray scene to corona scene?
I’m clickin’ START CONVERSION and no magic happens ;/ still viewports are black ;/
( I have lights, cameras, environment in vray mat)
Please help.
Make sure that you assigned Corona as production and material editor renderer. Render settings>common>assign renderer
This may be useful:
https://coronarenderer.freshdesk.com/support/solutions/articles/5000549705
Note: The converter will only convert Vray materials if Vray is installed.
Yeah… And if Corona is installed. ![]()
I guess you can use Vray demo.
@mazta87 - I don’t have Vray myself. That’s why I told you this. I do a manual conversion in such cases, but Maru might be right about the Vray demo.
Yes, all of this is true, thank You a lot (demo vray helped).
I have rendered in Corona my model but nearly 90% of bought environment (evermotion) is interpreted as a simple box(!). What is the best way to ‘swap’ all of the plants to be shown as a plant not as a coloured box?
These boxes - are they Vray Proxy objects? You would have to convert them back to geometry or Corona Proxies.
See here:
