Vray toolbar icons too small
I’ve got a 4k display, windows 10, max 2019. Most, if not all, of the max icons and text are more or less big enough. But the vray icons are too small. I have changed the windows text size etc. to 200%, and I have tried the adding the vray environment variable set to 2 or 3 mentioned in another post which didn’t change anything. Ok I see now that I was mistaken. The max icons are at 24 pixels square, and I assume the vray ones are too. I’m going to test what happens if I make bigger ones.
Support for high DPI monitors for the V-Ray toolbar is already on our to-do list. We will notify you, when there is any progress.
Best Regards,
Martin Minev
Chaos Group Support
I found Max to be a pain in the arse at 4k (and other programs too) so I ended up reverting to 2k. I honestly don’t miss 4k, but it is a shame that a lot of programs aren’t ready for 4k.
Any progress on this?
