Short question: Is it possible that vray toon isn’t compatible with the Vray Clipper object? It seems that Vray toon is still outlining edges of clipped areas. Which by itself creates an interesting effect but sadly not what I need ![]()
Yes this is a known limitation of VRayToon and VRayClipper. It is in our “todo” list to fix it.
Best Regards,
Yavor
Thanks for the answer. Is there any known workaround?
The only workaround that I can think of would be to attach all objects into a single polymesh, then apply slice modifier with Remove Top or Bottom option and then apply Cap Holes modifier.
