VRay Toon to only affect the VRayToon render element and not the RGB
Some improvement have been finally made with the addition of the VRayToon render element and it’s great !! but to be fully functionnal, it would be nice to have an option to make the VRay toon “invisible” (not baked) into the RGB/ effect result but only affect the VRayToon render element.
Maybe it’s already possible but I didn’t found out how to make it
Also, the Color Mapping checked seems to yield worse result overall and should be unchecked by default IMHO
Hi @Pixelab ,
Thanks for the suggestion! This has been added as a feature request and we will keep it in mind for future product improvements, however, we cannot give you an estimate for when it can be added for certain.
For the time being the only workaround you can use is to render the images twice (once with VRayToon enabled and once with it disabled).
