Okay, I made a bunch of new tests. First, I built up a new scene in Maya 2020.1. Then I made a fresh install on the 64 core node (Maya 2020.1, Vray 5.10.20, PhoenixFD 4.41.00)
Test1: 2500 pix wide (Sea, Foam, Splash, Boat)
CPU: Compiling from 2% → 56%
Building embree 100%
Render start at 100% and dropping down to 50%
Test2: 2500 pix wide (Sea, NoFoam, NoSplash, Boat)
building embree 100%
Render start from 100% up to the end
Test3: 2500pix wide (Sea, Foam, NoSplash, Boat)
Render start at 60% and dropping down to 36% → up again to 50% (I didn’t let it finish)
Test4: 2500pix wide (Sea, NoFoam, Splash, Boat)
CPU: Compiling from 2% → 48%
Render start at 100% and dropping down to 70%, then 42%, then 38% (I didn’t let it finish)
Test5: 2500pix wide (Sea, Foam, Splash, Boat) No Motion Blur on Foam and splashes
CPU: Compiling from 2% → 51%
Render start at 50% and dropping down to 36% (I didn’t let it finish)
Test6: 2500pix wide (Sea, Foam, Splash, Boat) Point Mode for Splash and Foam (all previous were with cellular (foam) and splashes (splash)
CPU: Compiling from 2% → 52%
Render start at 100% → 60% → 80% → 90% → 99% (render completed at 10%)-> 60% (render complete at 20%)-> 99% up to end
Test7: 2500pix wide (Sea, Foam, Splash, NoBoat) Again with cellular (foam) and splashes (splash) - Bucket 32 (like all previous)
Test8: 2500pix wide (Sea, Foam, Splash, NoBoat) Again with cellular (foam) and splashes (splash) - Bucket 8
Render start at 33% … (I didn’t let it finish)
Test9: 2500pix wide (Sea, Foam, Splash, NoBoat) Again with cellular (foam) and splashes (splash) - Bucket 128
Render start at 70% then dropping down to 45% (I didn’t let it finish)
Test10: 2500pix wide (Sea, Foam, Splash, NoBoat) Again with cellular (foam) and splashes (splash) - Progressive
Render start at 100% then dropping down at 40% (I didn’t let it finish)
So… only thing which is sure is that CPU utilization has to do with particle system of PhoenixFD. All other tests have a similar pattern of behaviour.
I will send the scene to support, without the boat. All my test renders were done at frame 1041 and camera1, and I will send the corresponding AUR file.
I’m curious to know if I have any bad setting here.
