VRayBitmap vs Bitmap viewport display - VRayBitmap not working correctly
Hi Guys
In Max 2021, VRayBitmap is not displaying correctly in viewport. Its showing 1 version of the texture, with the rest where it would typically repeat or tile, showing black. Regular bitmap works fine though…
What version of V-Ray are you using? Could you attach a simple scene or a screenshot of the issue?
I’m reviving this post…
V-Ray 5 update 1.2
3ds Max 2021.3
GeForce RTX 2080ti - driver version 461.40
VRayBitmap - does not show shaded texture properly in viewport
simple material with stochastic tiling turned on
- shows on material ball and in rendered/IPR
- does not show up in viewport shaded mode
@pixelplume This is another topic and it is normal. The Stochastic Tiling option is calculated during render time, hence why there isn’t a viewport preview.
thanks for letting me know :slight_smile:
