VRayEnvironmentFog
How do you pick multiple lights at once?
I thought it would be similar to the Light Select element, where you select all the lights, click Add, and then go into the Select By Name and the lights should all be selected are highlighted, then click Ok. But only one light gets added to the list.
I’m using Vray 3.20.01
Actually this functionality is scheduled for one of the next service pack releases.
Ha, nice. Yeah I don’t use the effect enough. Only realized the shortcoming today :slight_smile:
But I do love that method of adding groups of objects to lists, through pre-selecting and going into the scene manager.
Yes, it will works the same way - in active ADD mode, all lights picked from the Select by name dialog will be added to the “Lights” field.
