VRayFastSSS2 working with vantage 3.1?
I can’t get any Vray FastSSS2 subsurface scattering working in vantage live link, neither with Alsurface …is it not supported yet?
It just seems to render the diffuse, no SSS at all no matter what settings I adjust
I know I can use translucency in the VrayMtl shader, this works, but prefer the other two options for better control .
is there a setting I am missing? SSS switched on in Vantage
I’m on 3ds max 2025, RTX 5080, Vantage 3.10, Vray 7 update 2 hotfix 3
'edit sorry wrong forum!! …cant delete post.
FastSSS2 and AlSurface shaders assigned to a geometry will render in Vantage, but they won’t have the scattering effect. It is not supported yet. The colors for scattering will be used as a diffuse only. For now in order to get the scattering you need to use the VrayMtl with transilient set to SSS mode.
You can add a request in the ides portal here : https://chaosvantage.ideas.aha.io/ideas
