So it seems VRayHDRI display in viewport from environment is BROKEN in 2015. It works fine in 2014.
Tried various things in 2015 to make it work, and all I get is a white screen.
So to reproduce (either in 2014 or 2015)
Make new blank scene
Add hdri in environment slot and adjust multipliers etc
In viewport, display environment
Works fine in 2014, but same steps do not work in 2015. Tried with realistic display, shaded etc. Tried in material editor to display in different ways, but end up with same white result
Could be something in MAX changed again in 2015
Although in 2014 I tested it with VRay 2.4 and in 2015 I tested it with VRay 2.5
No, the V-Ray code didn’t change, I think. However, the Nitrous implementation is being actively developed and changes from release to release - it may very well be that we need to do something differently for 3ds Max 2015.
